Old 18-09-2005, 06:26 PM   #1 (permalink)
mad
Default Help me
I had a pdf file in which there is my maths sample papaer
evrything inside it is in black
unfortunately my printers black in is finished but other inks are there
how do i print whole in the blue colour
i tried to convert the pdf into other format i.e pdf to .doc
but in the .doc file evrything after presing ctlr+a changed into blue but not the geometrical constructions
how do i do it ?
editing each image will take me years !
how can i print the pdf file direclty inot the blue colour man ?
mad is offline
Old 18-09-2005, 07:01 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
hmm u can get some software which will trancefar that PDF document in other format like word or excle or openoffice documents.... where u can edit it easily...
check the bellow web site...
http://www.abbyy.com/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 18-09-2005, 09:27 PM   #3 (permalink)
mad
hey i have already tried that
converted to .doc
but since they are geometrical constructions and many figures are there (in one figure there is 5 to 6 lines)
editing each line and converting it to blue colour will take me years
also please tell me the best
PDF to doc converter
i tried solid converter but it cannot perfectly convert the mathematical equations
help anyone
mad is offline
Old 18-09-2005, 11:41 PM   #4 (permalink)
Rebooting
if it is posseble then pls share that exact (pdf) files with us... then it will b little clear.... what exactly can b done...
rebooting
ChotoCheeta.com
Old 19-09-2005, 06:30 AM   #5 (permalink)
mad
ok here is the link to the pdf file
http://cbse.nic.in/curric~1/Math06.pdf
mad is offline
Old 19-09-2005, 01:36 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
well, one long way is to click on each figure like say the circle and apply it whatever colour u like to...
;( too long......
Try creating images out of it if u can and then i guess with some Pshop help u can make all black blues (pun !)
Dunno sure if converion to images is possible but got this idea from an option to print as images in the print menu of adobe acrobat
Harsh J
www.harshj.com
QwertyManiac is offline
