Old 18-09-2005, 11:05 AM   #1 (permalink)
Default Why it happen's like that?
It happen me in past but i want to know why it hapen?
After the installation of LINUX.I was not able to go to windows (and the grub has no problem).And the key board dosen't work.I can't even enter into BIOS.When i boot into linux the keyboard work's.when i have tryed to install xp again after inserting the CD It prompt's as usally(Press any key to boot from cd).But here also i am not able to work with KEYBOARD.so that also fails.so i have resent my pc to retailer and clear it.
what happen?why i have got such a problem?what could be the reason?Anyone...
(None of window's booting cd work's)
rajas700 is offline
Old 18-09-2005, 01:11 PM   #2 (permalink)
desertwind's Avatar
its really odd!! i've never heard anything like that before. how can a gnu/linux installation affects working of bios ?
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 18-09-2005, 01:24 PM   #3 (permalink)
That only don't know.what happend???
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 18-09-2005, 03:11 PM   #4 (permalink)
desertwind's Avatar
i dont think linux is culprit here. just change ur keyboard and try
Old 18-09-2005, 03:58 PM   #5 (permalink)
The keyboard works fine with another computer.when i give my pc to vendor he said the CEMOS battery is down so he changed it as like he said.But how come LINUX ALONE WORK???(keyboard).
rajas700 is offline
Old 18-09-2005, 05:16 PM   #6 (permalink)
tech_cheetah's Avatar
maybe thats the power of linux to work even with discharged batteries.
Be honest . By that way u can be sure that the world is short of atleast one rascal.
tech_cheetah is offline
Old 18-09-2005, 05:37 PM   #7 (permalink)
I want the right answer.so in future i can correct.
rajas700 is offline
Old 18-09-2005, 11:47 PM   #8 (permalink)
desertwind's Avatar
and rajas, you must give better titles for ur threads
i found some of ur thread titles as
What is the use of these?
why it is like?
My desktop how is it?
Try
and more...
This is not gonna help. of course u have given appropriate titles for some threads, do it for all
Old 19-09-2005, 05:26 AM   #9 (permalink)
ok i fill meaning full.
rajas700 is offline
