Originally Posted by Official Techie
i got a message that windows require 200mb to run
and there is only 161mb
may b the messege is not for low disk space worning... now to check... do this...
go to
My Computer right click on the driver where u have windows XP install... now in the menu... click
Properties....
in there u can see how much space is free...
now if u have planty (more that 1.5 GB)... then this worning might have came from other source... like Page file size in too small...
How much ram do u have??
Normaly u should have atlist 512MB of Page file... just make sure u have that done... & try to set the page file in a different drive rather that in the same partition where windows is located....
follow this guide to
adjust the virtual memory setting set the page file in a different drive rather that in the same partition where windows is located.... & delete the default page file which should b in the OS drive....
