Old 17-09-2005, 07:41 PM   #1 (permalink)
maharajadhiraj's Avatar
Default shortening movie file help
how can i shorten 707MB movie file to 700MB file? should I use divx or any codec? won't the quality be bad if use them???? please help.......
maharajadhiraj is offline
Old 17-09-2005, 08:17 PM   #2 (permalink)
abhishekkulkarni's Avatar
He He , I think the Doctor ( Dr.Grudge ) would be interested in this ...
Man why did you not think before you hit the Submit button ? :roll: :roll:
There is a lot of difference between a Tutorials section and a QnA Section of any Forum , is there not ?
Reporting Post . Mods please move this ...
abhishekkulkarni is offline
Old 18-09-2005, 06:42 AM   #3 (permalink)
expertno.1's Avatar
Well the answer is yes
download virtual dub from here
http://www.virtualdub.org/
downlaod divx helium codec from here
http://labs.divx.com/archives/000055.html
install them
now in virtual dub
use the compressoin option
select the divx compresiion and edit the changes
make the video a little bit smaler or decrease the kbps sttream from there
or else
u could try anothr feature i.e
Overburning
How to overburn
http://www.tacktech.com/display.cfm?ttid=253
this will surely fit yours 707 mb in your 700 mb
Thanks
Regards..
Expertno.1
expertno.1 is offline
Old 18-09-2005, 11:39 AM   #4 (permalink)
Default thanks
thanx quite a lot for your help
