Old 16-09-2005, 11:20 PM   #1 (permalink)
Default Guestbooks ???????
I am in need of Best available free Guestbok that I can add in my college site.....
Or rather just tell me the way to develop simple guestbooks since I want this to collect the feedbacks of articles....
Sarwesh is offline
Old 17-09-2005, 12:35 AM   #2 (permalink)
tuxfan's Avatar
If you know PHP and MySQL, developing a guest book is pretty simple. Do you want me to give you logic and DB design?
But there are a few ready ones available. I don't remember the links now. Will find it out and post.
tuxfan is offline
Old 17-09-2005, 12:51 AM   #3 (permalink)
Default Sorry!
I dont know PHP and MySQL since I am doing Electronics & Communication Engineering, I am a complete novice in this field but if u can give me logic & DB design as u said I can have a look to that....
Or tell me the free sites which doesnt give link back to their own site as this is a college site & moreover I have to use that for collecting feed of articles.....
Sarwesh is offline
Old 17-09-2005, 01:22 PM   #4 (permalink)
bukaida's Avatar
Default Check this out
Check the following link. you require apache and php4 to run this code.
If you have old digit cd, both of them were provided there. Else you can download them from www.apache.org and the php binaries from
http://in.php.net/get/php-4.4.0-Win32.zip/from/a/mirror. The installation Guide can be obtained from http://www.thesitewizard.com/archive/php4install.shtml.
Now finaly The source code .
Remember to install the apache first mentioning localhost to both server and domain field. Select all the default options.Be very much careful here.If it is wrongly installed once, It is very difficult to get it worked.Post for any further suggession.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 17-09-2005, 03:41 PM   #5 (permalink)
tuXian's Avatar
Find from your college if the site is hoasted on Linux. If yes then the CPanel i.e the webserver user interface has many pre-built scripts. that u can use.
Of course custom guestbook is something special and the Cpanel ones are common.
tuXian is offline
