Old 16-09-2005, 10:00 PM   #1 (permalink)
champ_rock
champ_rock's Avatar
Default Copy protect cd
hey guys........
i want to copyprotect my cd's that i create so that nobody is able to create copies of them..........
can anyone tell me how to do it.......
champ_rock is offline
Old 16-09-2005, 11:15 PM   #2 (permalink)
Normally no such a software not avaliable i think.lot of tool's like vritual cd are there so no chance.using virtual cd as like the original cd u can copy.
rajas700 is offline
Old 17-09-2005, 12:04 AM   #3 (permalink)
Default CD to CD Copy :: Protection
There is solution to protect CD to CD copy::
Yes u can protect from CD to CD copy, by using a soft CD Manipulator
This has the capabilty to make as hard as 30 minutes hard to copy CD's which can't be copied from normal burning softs like Nero...
But, as u must be knowing that every protection has solution, u can crack this by using softs ......
But u have to make more protection, since it can be copied to Hard Disk & than to CDs....
For dummies it works.....
There is another soft Free 128bit Encryption Software which protect the data on ur CD's by encryption, I have tried this but atlast it didnt work...
Sarwesh is offline
Old 17-09-2005, 12:18 AM   #4 (permalink)
That is what i have said.look up.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
