Old 27-09-2004, 04:41 PM   #1 (permalink)
Default Problem with hitman 2
i have compaq presario 3705 bought 3 years back.i bought original hatman 2 cd a year ago and it ran perfectly then.but now if i try to run it,it looks as if it is gioing to run but it again returns to the desktop.plz help.[/b][/i]
deepinder_mann1988 is offline
Old 29-09-2004, 01:27 AM   #2 (permalink)
I don't know y this prob.
But hitman 3 does the same. Hitman 2 wrks fine. So just do as i tried for 3.
if you hv XP then right click on it, choose compatibility and choose resolution of 640x480. it shud wrk
I am not sure But I think Hitman 2 dosn't wrk on 98.
Wat is ur OS? tel me if d abv wrks
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 29-09-2004, 08:16 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Please give a more detailed description (ur OS, any error msg, hardware etc).
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 29-09-2004, 10:39 AM   #4 (permalink)
mohanty1942's Avatar
deepinder,
Insert the Hitman 2 CD into the tray. The autorun screen should pop-up. Now before clicking the play button, select the 3d Renderer (display in the pop-up window)setting to OpenGL & Direct 3D alternatively simultaneously changing the resolution setting.
This should solve ur problem. Notice me if it doesn't work.
No Terms : Just One Condition
mohanty1942 is offline
Old 29-09-2004, 05:18 PM   #5 (permalink)
i had win ME. use to play hitman 1 on it.then i put win xp. same prob as u. once da game starts, da next second it closes n da desktop comes bak. no error msg. even tried using diff compatibily modes n all.
ishaan is offline
