Old 15-09-2005, 07:18 PM   #1 (permalink)
Default any php programmer around
i have just started php and i have learn many thing from books and may be some web experts help.
i have some problem though
hope it will be solved here ..just have not seen much php discussion here..
problem1)
the user name and password are stored in database table ..the user enter username and password and it is checked against the password and username in tables
now problem is if uname and pass are correct i want user to direct to thier personal profile page...if user can see only his personal profile
how is it done ?
is it making query
select .....from tables where uname=required and pass=" "
or we make separate page for each
are there simple example code in any web site
query 2) does php run in IIS (other than in aphace)
i am unable to make in run in IIS though some books says it can
then how
query 3)
when searching i want to search in certain tables only how it can be done
i want search result from password protected area
how it is done
by the way does phpbb forum run in intranet?any configuration details or intranet or is it same..
thanks for your replies
saha
be who u r :
Saharika is offline
Old 16-09-2005, 04:47 PM   #2 (permalink)
i am unable to make in run in IIS though some books says it can then how.
It can run, but you will need the php modules/server for it.
It is the same.
Edit:techno-Edited this post to make it more legible
valtea is offline
Old 16-09-2005, 07:18 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: any php programmer around
Originally Posted by Saharika
problem1)
Tip 1: Dont store your passwords in the database in plain text. Use some kind of hashing algorithm to make it secure. Use PHP's md5($string_variable); to generate MD5 hash and save that in the database instead.
As for your query,
Let's say you have a homepage as home.php then you can do something like this.
if ($username == $database_username && $passwd == $database_passwd)
  header('Location: home.php');
  exit();
else
  header('Location: login.php');
  exit();
http://web.gnuer.org
GNUrag is offline
