Old 15-09-2005, 06:48 PM   #1 (permalink)
Default Data Recovery solution needed!!!!! Can neone help?
Well fewdays back i updated my bios and the next time i switched it on i got the blue screen. tried to reinstall XP but didnt work. Well later i found out that the RAM went kaput (wonder how updating a rom affects ram :roll: ).
Well now the compu is up and runnin i am in a new prob. I had some imp documents in MY DOCUMENTS. But I am being denied access to that folder. I have a NTFS partition. Well since the data wasent deleted and hence i am unable to use PC inspector file recovery.
Can neone help?????????????
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
Sankalp is offline
Old 15-09-2005, 08:03 PM   #2 (permalink)
this should solve ur probs
http://support.microsoft.com/?kbid=810881&sd=RMVP
ishaan is offline
Old 15-09-2005, 08:47 PM   #3 (permalink)
hey thanx buddy!!!!!!
Problem solved
Sankalp is offline
Old 17-09-2005, 11:29 AM   #4 (permalink)
your welcome....it wz easy to find on google...i searched for 'xp my documents access denied'
ishaan is offline
