I have a P IV system 2.0 GHz, 128 MB RAM, Mercury Chipset Mother board, 40GB HDD with OS as Windows XP. The problem is the system is too slow and it takes too long to even start a Word or Excel file. Our system engineer suggested to format harddisk and reinstall the OS. Even then the problem continues. The engineer does not have any answer for this and he suggests to format it again.
Please tell me a suitable solution to overcome this problem.
Hi udhaybhavan ,
these are the possibilities of slow speed
1) Very less ram
2) Overload of softwares
3) Less Paging memory
4) Bad sectors on HDD
To cure these do this
1) get a good system performance boost software
i recommend Dr. salmans window power tools 4.7
http://www.topshareware.com/Window-P...nload-3671.htm
http://www.shareup.com/Dr.Salman's_Window_Power_Tools-download-4000.html
or get system mechanic
www.iolo.com
2) do scandisk
3) do defragmentaion of the hard disk
4) clean up the system tey useless softwares
5) cleann up the uselse on startup softwares from
the msconfig
Thanks
Regards...
Expertno.1
