Old 27-09-2004, 08:52 AM   #1 (permalink)
dare_dexter's Avatar
Default XP's giving problem- sos!!
Guys, I'm facing a problem with my Windows XP. I've installed various patches and updates(including the one called "System Recovered From Error"), and now I'm unable to defragment and perform anti-virus scan with Norton Antivirus 2003(updated online) to my C: drive, where Windows remains. The problem includes the file sysdata.xml.
Please help. My C: partition is about 12% fragmented!!
I just wanna live when I\'m alive
It\'s my life!!
Dexter
dare_dexter is offline
Old 27-09-2004, 09:42 AM   #2 (permalink)
Did you install the latest service Pack (sp2) ?
Also, dont use the default windows defrag program, its practically useless. Use alternative programs like Diskeeper or O&O Defrag, or even System Mechanics' defragmenter are much better than the defrag program.
But before doing a defrag, perform a full and through chkdsk by running the following command:
chkdsk C: /f /v /r /x
You'll get a message saying that the drive is in use and it cannot be checked, and whether you'd like chkdsk to run at the startup. Press 'Y', and restart your comp.
After the chkdsk, restart and start your comp in safe mode and try to continue the defrag.
But if possible, try to install SP2 and use other Defragmentation programs.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 27-09-2004, 03:02 PM   #3 (permalink)
Default Thanks
I'll soon install SP2 in PC. Does it solve my problem?
Is there any freeware with which I can defrag my disk?
I have another question to ask. Why can't I activate my account in RED HAT Linux 9.0 (which I got from Digit CD Pack)?
It\'s my life!!
Dexter
Old 02-10-2004, 12:31 PM   #4 (permalink)
rajat22's Avatar
Install SP 2, Defrag with 3rd party defrag tools or try POWER DEFRAG with Windows defrag tool.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
