Hi Ashis ,
my recommendation is Cute FTP pro
This program allows you to transfer files between your PC and remote computers. You can use it to publish a Web page, download images, music and software, or transfer large files between your home and office.
Besides its supports resuming feature too
A file-transfer application that's both easy-to-use and powerful
Drag and drop and other user-friendly features
Macros to record and play back frequent tasks
Queued uploading and downloading
Complete directory overwrite and delete
CuteFTP is a file transfer application that's easy to use for beginners and has enough features to be useful for power users as well. It uses drag and drop, bookmarks, automatic renaming, and download resuming to make FTP easier, and it includes a macro feature that you can use to record frequent tasks and play them back later with another file. Other key features include directory upload, directory compare, remote site editing, queued uploading and downloading, complete directory overwrite and delete, and a progress rate display.
CuteFTP also offers MP3 and file searching; a persistent file transfer feature that automatically reconnects and resumes a transfer until the file requested has been successfully uploaded or downloaded; a site wizard designed to aid users in connecting to their FTP sites; integration with CuteHTML; right-click action on your PC to automatically send files to selected sites; connection/transfer error prompts; Windows Explorer integration; remote file editing; and the ability to delete to the recycle bin. New CuteFTP 4.0 features include a redesigned interface, SOCKS 4 and 5 support, Smart Keep Alive, custom firewall options, Encrypted Site Manager, an auto update feature, log options, and more.
Thanks
Regards...
Expertno.1
