Old 14-09-2005, 01:46 PM   #1 (permalink)
Default Upgrading
Hi to all out there, I am willing to update my PC which I brought good 4 years back. Its ::
P3 800MHz,
256MB Ram,
VIA 601 BS4 (8 MB Video Card)
No AGP Slot
Well the update can be RAM (1GB P3), G Force(PCI Slot), but all this are not available in the market ........
HELP
Sarwesh is offline
Old 14-09-2005, 01:48 PM   #2 (permalink)
MVP in VC++
What is u r budget? and what is the purpose of upgrading?
cvvikram is offline
Old 14-09-2005, 01:57 PM   #3 (permalink)
Well the Budget is upto 5000 & its just for normal use as it's really slow..........
Sarwesh is offline
Old 14-09-2005, 01:58 PM   #4 (permalink)
club_pranay's Avatar
what's your mobo? make sure that the mobo supports what you buy esp RAM, processors, High end HDD (my old pc never suppoorted hdd>32gb)
P3 800MHz-- your mobo may not support processor more than 1ghz! so there's no point upgrading the processor(oonly 200mhz diff)
256MB Ram.. most probably it's a SD ram... after the ddr came into the market the SDRAM has been going thru a slow death.. ppl hardly use them.. but keep searching(i wish we had the bazzar section up!!)..
No AGP Slot
that's a prob!!--- PCI graphics were no where near the AGP ones.. so no place for them in the market too... and now this PCIe!! .. this PCI graphics card may cost you a bit on the heigher side(if you were lucky to find one)
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
