14-09-2005, 11:13 AM
Cool as a CUCUMBAR ! ! !
Protect files/folders on my CD-Rs ! ! !
I have a lot of personal information on my drives and back them up on CDs.
Is there anyway to password-protect these files/folders on my CD-Rs so that no one else can view the contents???
I am running Window XP sp2
14-09-2005, 11:46 AM
Commander in Chief
U can use RAR compressor with passwords or also use folder-lock-xp (shareware  )
14-09-2005, 01:18 PM
Core i7 (nehalem) Owner
hey buddy..so u mean that we chud convert our files and folders using WinRAR compression and password protect it??
If u can giv a detaild info then it will be helpful to all of the users here..including me..
thanx..mate..,
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
14-09-2005, 01:38 PM
Commander in Chief
K Simple,
Put all the files u need in a folder and rightclick it and go to Winrar > Add to Archive ...
Now in the menu that appears, choose ur compression level, filename, blah, blah and go to the tab, ADVANCED ...
Now u will see a button Set password !
Click it and set ur password and the option for encrypting filenames etc....
and then press ok and create ur archive after verifying all the needed options !
Hope that helped !
Qwerty
14-09-2005, 01:43 PM
Hey thanx a lot Querty....it workd man..thanx again...
cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
14-09-2005, 01:51 PM
MVP in VC++
Yes it is a good idea to compress the files/folder and make it password protected and it also saves space....
14-09-2005, 02:14 PM
Softs
Well! U can use Cryptainer LE - Free 128bit Encryption Software for protection & if u want to protect from CD to CD copy than use CD Manipulator which can make 30 min hard to copy CD's........
14-09-2005, 09:25 PM
You can even use winzip for this purpose........
14-09-2005, 09:50 PM
Use CD-Lock.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
14-09-2005, 11:13 PM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
download link for cd-lock????? is it freeware?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
15-09-2005, 12:52 AM
Please giv the LINKS guys....it will be really helpful coz even i wanna hv my files protected wen i burn it on a CD...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
15-09-2005, 06:17 AM
You may even use folder lock to lock up the folders.
www.tucows.com/get/354522_131613
16-09-2005, 04:19 PM
bt compressing through RAR ... wont all files b mixed up ...
say, there wont b any folders only files ...
... W H O T ...
16-09-2005, 06:44 PM
Commander in Chief
Nope as i said place the files in folders and then rar it. (the main folder)
16-09-2005, 07:03 PM
Guys if we use folder lock , and then we try to open the files in some other computers which do not have folder lock installed , will we be able to open the files.
\" I Do not like to repeat success , i like to move on to other things \"
16-09-2005, 07:25 PM
Commander in Chief
Yes if u create a self extraactor lock type (i think with a safe like icon)
Search this Thread |
