i am facing a strange problem with my hard disk..
i have two hdds, a seagte 40 gb, nd a 20 gb, both 5400 rpm.
i have two separate installations of windows xp on the two hdds...which i use when required.
yesterday i had plugged in the 20 gb hdd as master and when i tried to boot it said "primary master failed" and booted from the slave.but even then windows couldnt complete booting and stopped just b4 the login screen.
i next plugged it as the slave and the same prob was repeated.
then i booted with my win98 boot cd..(my smaller hdd is partitioned fat32),but it couldnt detect it at all!!!same problem with the xp boot cd.
then i booted with the seatools boot diskette(it is a disk diagnosticutility from seagate) and it detected both the hdds, but while scanning the smaller one,it found "critical file system errors" in the primary partition(6 gb, fat32) and the 1st logical partition(ntfs,6 gb).the 2nd logical partition(8 gb,fat32)was found ok.
i then booted with the disk manager diskette..thinking i would take a backup of the healthy partition in my other drive..and then repartition it.but there..it is not showing the logical drives separately..and as a result i cant take the backup.
i hv some imp data in this disk..and i need to recover as much as possible.any help wld be very appreciated.
ps:when i enter the bios with the faulty hdd pllugged in..it is not detecting it automatically..whether it is master,slave or alone.i have to manually enter the cylinder,sectors etc by defining it as "user definrd",and then when i redefine it as "auto",it is getting detected.
any help is sought after..
thnx
