limewire is infested with junk files of sizes 851 kb... is there any way to remove them?
i too face d same problem and these files are trojans. u search for anything on limewire and thousands of these 851 kb rar/zip files pop up. i downloaded one once and kaspersky detected it as a trojan so be careful guyz .. and do tell us how to get rid of these 851 kb trojans ??
well i think that was with a beta version of limewire.
try out the latest.i too faced the same problem but now i use the final edition and there are no such files.
i am using the final latest version i.e Lime Wire Pro 4.9.28
Just check... see that the size mentioned matches the approx size. ie. if you are downloading an mp3 then it should be around 3-5mb but if it is 859kb then it is something else. Therefore hit and trial method has to be used. Be sure to use an antivirus and a antispyware while using Limewire
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
hey i'm using limewire 4.8.1
is it a beta version? i can't find any mention of it newhere
my anti-spyware did not detect any spyware though..
what registry files are you talking about?
and in which form does this trofan manifest itself?
Before you criticize someone you must walk a mile in their shoes...that way when you criticize them you\'re a mile away and you have a new pair of shoes!! :)
Limewire 4.8.1 is not a beta version but an older version.
Don't download files of size 851.7KB They are automatically generated files with names of very pouplar softwares and games. Use commen sense while downloading.
fastrack: make sure that your firewall is letting limewire connect. also enable Out Of Band searching in the options and try toggling the Ultra Peer option.
the 851.7 kb files are all over the place. search for anything and most results will be of that size. all of them are trojans and sadly not all AVs detect them. i had a really bad experience with one of these. the only way around is to check the size of the file you want from some other website and download it only if it is something similar. mp3s are not a problem cause you can preview them soon after starting.
limewire is by far the best app for sharing (excluding torrents). i am using 4.9 pro
i deleted all the contents of the folder blitz`kreiz
the folder is an invisble one;
even u turn off "hide folders" frm folder menu;it wont show.
so manually access by typing the address and then delete the contents
