Old 13-09-2005, 10:02 AM   #1 (permalink)
Default cannot play .mov files in itunes or quicktime
Im unable to play .mov files either in itunes or quicktime. the videos are really jerky, a frame changes after every 3 or 4 secs. then the application hangs or closes, quicktime gives some kind of error that file is corrupt. but this happens with every .mov file which I had played earlier correctly. this does not happen with .avi or .mpg files. also if i do not display the video in itunes and listen to the song only, then it does not close, but the moment i open the video pane, it starts framing(the video only, the sound is normally played). so what should i do? i have reinstalled itunes and quicktime and then downloaded and installed the latest ones(5 and 7), but still no results.
Athlon 64 2800+ | MSI K8M-Neo-V | Seagate 160 GB PATA | 512 MB Simmtronics DDR400 | Creative Inspire 5200 5.1 | Philips 107E5 17\" Monitor | Sony DVD-CDRW | Microsoft Internet Keyboard+Logitech MX518 | XFX Geforce 6600GT 128MB AGP |
HellGuardian is offline
Old 13-09-2005, 06:14 PM   #2 (permalink)
Default Re:cannot play .mov files in itunes or quicktime
Dear Hell Guardian,
I think there must be some connectiviy issues between Earth & Hell. Please come to earth and try downloading again. May be you won't face any problem
Srinath.
shrinathv is offline
Old 13-09-2005, 10:24 PM   #3 (permalink)
dear javagal srinath,
maybe u can come back from cricket, i have downloaded and installed itunes many times, and this rpoblem exists with 4.9 and 5.0 both. i think its a problem with something else, maybe codecs and not itunes or quiktime
