Old 13-09-2005, 02:07 AM   #1 (permalink)
bang bang!
Chirag's Avatar
Default MalFunctioned. What is that?????????
Recently i bought data cable for my reliance fone to connect to internet. It worked fine till one week. Then one day suddenly my internet stopped and an error came - "A device connect to USB have mal function and widows cannot recognize it". And after that windows install(XP)unknown driver. I can't even update.
I make my internet work after installing and uninstalling data cable driver more that 5-6 times.
Today i wasted 40-45 mins to connect to internet. Help me
Chirag is offline
Old 13-09-2005, 08:50 AM   #2 (permalink)
This is a Data Cable driver problem. The same occured to me. Goto Relianceinfo.com and download the latest drivers there once you get your connection working and install them all your problems will be fixed.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
