Old 13-09-2005, 12:56 AM   #1 (permalink)
Default cd writing error
i have a sony dvd combo drive...... when i write a cd it writes upto 3 percent and then stops for a while........ after that it gives cannot perform fixation erorr... wat should i do???????????
ashishkhetriwal is offline
Old 13-09-2005, 01:29 AM   #2 (permalink)
#/bin/sh's Avatar
What burner do you have? > Nero ?
Try installing Nero 6, with latest updates on the website..
please post all error you gets.
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 13-09-2005, 06:11 AM   #3 (permalink)
Can you post the error log file of your burning software???
What media are you using? If you are using very cheap media then this is possible. Try changing the media to a different brand post your result here...
shivaranjan.b is offline
Old 13-09-2005, 06:35 AM   #4 (permalink)
q3_abhi's Avatar
Try to change the CD media ur using.
Try re-installing the software.
Try it on other OS.
Try it on friends computer.
Check out the cables.
Probably its the CD media problem
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 13-09-2005, 02:22 PM   #5 (permalink)
i m using nero 6 and i tried 3 different medias but still not working..........
Old 13-09-2005, 02:36 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try using a lens cleaner, must ave been covered by dust...
Else rely on ur warranty period.
Also plz install ASPI again and try.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-09-2005, 09:24 PM   #7 (permalink)
q3_abhi's Avatar
Try defragementing ur hard drive.
q3_abhi is offline
Old 13-09-2005, 10:11 PM   #8 (permalink)
What r your sys specs??????? Please post hte error log of Nero
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
