Old 12-09-2005, 09:03 PM   #1 (permalink)
Default Computer doesnt start...
My computer with Vesta mother board ,celeron 1 GHz has a new kindda problem... it doesnt start. Whenever i try switching it ON, the CD drive's light blinks and the Fan on the processor runs ,,and nothing else happens.
the monitor is blank.the keyboard's lights r not workin(may be it is also not working..)
Now wht do i do ?
Please help me...
Thanks in advance...
NOBODY
is perfect,,, I am NOBODY
chanduthebest is offline
Old 12-09-2005, 09:09 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think it is an obvious with the SMPS the power from the cabinet is not reaching the peripherals so check for that and it should be alright !!!!
vijay_7287 is offline
Old 12-09-2005, 09:20 PM   #3 (permalink)
well the SMPS is working fine... it must be something else...
anyways thx for tht help...
NOBODY
Old 12-09-2005, 09:25 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
if ur sure that the monitor is starting up then it seems to an OS prob
trust evn i had such problems
try a boot cd and check ....!!!
Old 12-09-2005, 09:52 PM   #5 (permalink)
expertno.1's Avatar
@chanduthebest
you should reset the CMOS and then see if your computer boots or not
probably there might be also problem with the loose monitor connections
check them
do u hear any long beeps ?
expertno.1 is offline
Old 13-09-2005, 11:34 PM   #6 (permalink)
the connections are firm.
and i dont hear any beeps.
but the problem still exists.
NOBODY
Old 13-09-2005, 11:44 PM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Please remove the CMOS battery from its socket and reinsert it after a gap of 5 mins...
Also check for any loose connections from ur video card( if u hv) to ur Monitor cord...
Since there r no long beeps then there is no BIOS problem...
Keep posting ur results here bro !
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 14-09-2005, 12:43 PM   #8 (permalink)
Any of your req h/w components is not connected properly or is damaged.(eg RAM hard-disk) Open ur cabinet and re-establish all the wire connections.
The symptoms you described can also result due to an unstable conf in BIOS,but since u didnt temper with it,its possibility is ruled out!!
rkb2005 is offline
Old 14-09-2005, 01:29 PM   #9 (permalink)
the mobo seems to be at fault since the power is not reaching the peripherals and the signal not reachin the monitor
No Mercy, No Limits.
theraven is offline
Old 14-09-2005, 05:30 PM   #10 (permalink)
The Incredible's Avatar
Did u mnt that da computer doesn't beeps but da light of fdd n cd-rom glow for a few n ur monitor is blank.
OK.
First of all if u think that if smps fan is working then smps is also allright then u r wrong. just make it checked by any engineer also re-insert ur RAM.
Anindya Srivastava
The Incredible is offline
Old 14-09-2005, 07:02 PM   #11 (permalink)
I think unplug all the PCI devices and HDD Cd, DVD drives and attach only processor and Ram (if possible onboard Graphic) and start it. if you still do not hear a beep code then it must be a problem with either MB, Ram or processor. Try putting in a different Ram and then test again.
valtea is offline
Old 01-10-2005, 07:57 PM   #12 (permalink)
Thanks every one for ur help... the problem was solved by an enginner..he connected a new wire between the mobo and the CD-Drive..(is tht wire wht u call data cable..?).(he removed the old one ..ofcourse...)
Thanks again everyone !!!
NOBODY
Old 03-10-2005, 02:28 AM   #13 (permalink)
Yeh!
Old 03-10-2005, 11:41 PM   #14 (permalink)
how much does this data cable cost?
NOBODY
Old 04-10-2005, 02:04 PM   #15 (permalink)
not more than Rs35
Old 04-10-2005, 09:21 PM   #16 (permalink)
the engineer says it cost him 65 bucks... !!!
NOBODY
Old 04-10-2005, 11:44 PM   #17 (permalink)
either its costly there or he may b foolin u. better ask a vendor. i've bot it in 35 bucks.
