Old 12-09-2005, 07:37 PM   #1 (permalink)
Default Cool n Quiet stopped working
See the system specs in the siggy. Cool n Quiet was working fine. I reinstalled Windows and installed the same drivers that I had been using before, but Cool n Quiet isn't working anymore. I use CPU-Z to check the frequency. Initially it used to drop to about 994 Mhz at 0% load but now it stays at 1790 Mhz.
drvarunmehta is offline
Old 13-09-2005, 07:47 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Use RM Clock (http://cpu.rightmark.org) It is far better than quiet n cool for AMD processors.
kalpik is offline
Old 13-09-2005, 09:23 AM   #3 (permalink)
It dosen't make Cool n Quiet work. It only shows the frequency.
Old 13-09-2005, 12:59 PM   #4 (permalink)
siriusb's Avatar
U sure u changed the power settings in the screen saver tab?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 13-09-2005, 01:57 PM   #5 (permalink)
Doh! I forgot to do that. It's working fine now.
Thanks.
