First be more clear about ur problem, as I asked in my previous post!
Do u mean by going to Desktop properties and in Power settings, enable Hibernation? or clicking on hibernate option in shutdown dialog box?
U can try to disable the Hibernation, then reboot ur comp and try to delete the file hiber*.sys in C:\ drive ( I'm not sure about the name, cauz I don't use it ), then enable the hibernation again.
May be it solve the problem...
