Old 12-09-2005, 11:05 AM   #1 (permalink)
Default how to edit the registry in dos mode
hi, pls tell me how to edit the registry in dos mode without login into os
need to edit the key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
its urgent, pls give any solution
thanks
kumaran is offline
Old 13-09-2005, 12:03 AM   #2 (permalink)
swatkat's Avatar
Hi,
Are you trying to edit this from Recovery Console? And, which specific key/value "inside" Winlogon Key do you want to add/edit/delete?
If you can give the keys to be edited/added/deleted, i could try to make a .REG file for it.
http://swatrant.blogspot.com/
swatkat is offline
Old 13-09-2005, 11:20 AM   #3 (permalink)
need to change into HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
"Userinit" = "C:\WINNT\system32\userinit.exe,"
unable to login with recovery console
is there any sofware to edit the registry in dos?
kumaran is offline
Old 13-09-2005, 11:57 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Regedit runs both on DOS and Windows, but how can u run a s/w from the recovery console ?
Harsh J
www.harshj.com
QwertyManiac is offline
