Originally Posted by sidewinder
even 925series mobo is rare in India.Let me know if u find a 945 or 955 series mobo.
damn rite ...
@Aniruddh
For an Intel platform Intel mobos are the best unless u wanna tinker around and do some overclocking. So I would suggest going for an intel orig. board if u r not going to overclock ur cpu or dont need some extra rarely used features. If u find an Intel Orig. 925 or 955 series board then definitely go for it but i doubt their availability.
So now your next choice is Asus , MSI , Gigabyte (I recommend Asus). Among these you can go for the following ,
ASUS P5WD2 (Intel 955 X ) (recommended)
ASUS P5LD2 Deluxe (Intel 945P) (recommended)
ASUS P5AD2-E Premium (Intel 925XE , Support only ddr 2 533
ASUS P5AD2 Premium (Intel 925X , Again supports only DDR2 533)
Gigabyte GA-8I955X Royal (Intel 955x) (very good board and not that costly too ) (highly recommended) (priced around 10k)
Regarding your other queries ,
go for a motherboard which supports ddr2 667 mhz ram at the least. ddr2 533 is not recommended and is a bottleneck infact.
Go for seagate 160 GB SATA NCQ or Hitachi SATA 2 drives (recommended) ... SATA 2 drives have hit d market and they cost almost d same so no sense going for SATA now. I read in this months chip that hitachi 80 gb sata 2 costs only 3k. WOW.
6600 non gt is gr8 if u dont mind playing at low resolutions as u already said. if u want higher visual quality then n only then opt for the 6600gt. i suggest a gainward vanilla 6600 for u. It will cost you around 5500-6000/-
UPS everbody knows APC is the best and the most expensive. Go for a 800 VA UPS for your rig and if u can get APC in your budget then dont think of others. Else go for Numeric , TVS , Powersafe. Numeric 800 VA is available for 3550/-
