Then ur windows firewall may block the connection
to overcome just to for opera.firefox,etc.(Adding an exception )
You must be logged on to this computer as an administrator to complete this procedure.
Open Windows Firewall.
On the Exceptions tab, under Programs and Services, select the check box for the program or service that you want to allow, and then click OK.
If the program (or service) that you want to allow is not listed:
Click Add Program.
In the Add a Program dialog box, click the program that you want to add, and then click OK. The program will appear, selected, on the Exceptions tab, under Programs and Services.
Click OK.
If the program (or service) that you want to allow is not listed in the Add a Program dialog box:
In the Add a Program dialog box, click Browse, locate the program that you want to add, and then double-click it. (Programs are usually stored in the Program Files folder on your computer.) The program will appear under Programs, in the Add a Program dialog box.
Click OK. The program will appear, selected, on the Exceptions tab, under Programs and Services.
Click OK.
If you still do not find the program, you can open a port instead. A port is like a small door in the firewall that allows communications to pass through. To specify which port to open, on the Exceptions tab, click Add Port. (When you open a port, remember to close it again when you are done using it.)
Adding an exception is preferable to opening a port because:
It is easier to do.
You do not need to know which port number to use.
Adding an exception helps provide security, because the firewall is only open while the program is waiting to receive the connection.
After doing this if ZONE ALARM asks opera,firefox for outpost connection just permit.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
