Shareaza is a peer-to-peer client for Windows that allows you to download any file-type found on several popular P2P networks. Shareaza is FREE & contains NO Spyware or third-party products.
The 2.2 release comes with major updates/fixes/improvements for the program and the networks it supports.
shareaza is s***.
u get queued up in looooooongggg queues..and believe me it is much longer than wat i have said.i mean like i was queued up at position 4694th position for a 1 mb file.
upto u to decide...but if u ask me i would say torrents and http are the B3ST.
