Old 11-09-2005, 05:36 PM   #1 (permalink)
cybermanas
Posts: n/a
Default Remove image list in alcohol 120%
How do i remove an image file name from the list which is displayed when i right click on alcohol 120% virtual drive and select mount.
Old 11-09-2005, 06:34 PM   #2 (permalink)
simple .just go to the drive(alcohol 120% virtual drive )Right click on it and find unmount the image file unmount it.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 11-09-2005, 07:35 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well thats simple,
go to the main application and u will see the image in the list there,
jus right click it and select "remove from list".
thats it !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-09-2005, 11:26 PM   #4 (permalink)
cybermanas
Posts: n/a
ITS NOT WORKING.
Old 12-09-2005, 06:55 PM   #5 (permalink)
Commander in Chief
huh ! ? !
It works for me but.
K problem posted on alcohol's site ,
wait for answers here :
http://forum.alcohol-soft.com/index.php?showtopic=20714
Harsh J
www.harshj.com
Old 13-09-2005, 10:41 AM   #6 (permalink)
Commander in Chief
K for removin non existent ones , see this :
http://forum.alcohol-soft.com/upload...4834_thumb.jpg
Harsh J
www.harshj.com
Old 13-09-2005, 05:33 PM   #7 (permalink)
expertno.1's Avatar
ITS NOT WORKING.
if its not working then surely there is the problem with the virtual driver
please reinstall the virtual drives or reinstall the alcohol
also there might be problem with the image file you have mounted..it may be corrupt
so try out resinatalling the virtual drives and then see
also which os are you using ?
expertno.1 is offline
- by bhaskar
- by soumya
