You probably have some corrupted files or corrupted registry entries. Insert your 98 CD. If it loads and displays on the screen click Exit. Then go to Start, Run, type sfc /scannow ,click OK. The program will check for corrupted files and reinstall them.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
