@Lobo: Mac sucks? since when? As far as I'm concerned, it is the most perfect system.
- We have had so many PCs in the office and I have to go almost every few days to fix them, some problem or the other.
- They hang up now and then, get viruses, spyware. Mac does not (not never, but mostly does not) and I don't even use an antivirus.
- Sure they have lots of software, but quality software? Even MS Office for mac 2004 is much better than its windows counterpart
- When it comes to support, the comp takes almost a week before it comes (Assembled PCs). No boards are available for systems which you bought just a year back, everything changes.
- Support for the mac is like a piece of cake. If something is wrong with say, your optical drive, they will see if its damaged and replace the drive within just a few days. IN THE MEANTIME, YOU GET A STANDBY MACHINE. If there is so much as a dead pixel, they WILL REPLACE AND NOT REPAIR THE LCD SCREEN.
- as far as I'm concerned, and many others, MacOSX Tiger is far more advanced than Windows Vista.
- Tiger runs beautifully on even a 128 MB RAM system. I think you have heard of Vista's system requirements.
I'm like a bird... :)
