Old 10-09-2005, 11:19 PM   #1 (permalink)
Default Do i change the smps ?
I've got a AMD sempron 2600+ on a Asus a7n8x vm/400 With onboard Geforce 4mx and 512 mb of ram . The problem is that this system generates blue screen errors frequently. My SMPS is of 230v from Mercury. Can that be athe problem ? Do i change it to a 350v or 400v Supply
girish_b is offline
Old 11-09-2005, 12:00 AM   #2 (permalink)
I don't think SMPS will cause blue screen error.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 11-09-2005, 01:29 AM   #3 (permalink)
Let's clear up one thing first. Are you talking about V (voltage) or W (wattage) ?
pimpom is offline
Old 11-09-2005, 01:57 AM   #4 (permalink)
The Hardware Labs
mohit's Avatar
if its a 230 watts smps then change it immediately .. even if its not i always suggest going for a good branded smps such as antec,coolermaster , powersafe etc. go for powersafe 400w gold plated smps which will cost around 1500/- bucks. i dont guarantee that it will stop the blue screens though... for the blue screens try the following,
Run Memtest86 on your ram for atleast 2-3 hours. get it from www.memtest86.com
Check for loose / faulty cables.
Update all your drivers for all devices (modem,vga,sound,etc). perform a clean reinstall with xp sp2.
Flash your BIOS to the latest version.
Make sure your RAM is running at the specified timings and not below them.
mohit is offline
Old 12-09-2005, 11:57 AM   #5 (permalink)
i think i can go for it. I also discussed it with one of my friend yester day(11-9-2005) and he also said the same.
Thank you .. mohit, for your reply..
girish_b is offline
Old 12-09-2005, 04:40 PM   #6 (permalink)
the blue screen may be of some different reason but - u r using a 230 v SMPS for 2600+ AMD.... its better you change it to 450 V now immediately......
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
Old 12-09-2005, 06:20 PM   #7 (permalink)
royal's Avatar
blue screen might be due to RAm...
and yes plz change ur smps to at least 350 W
royal is offline
- by bhaskar
- by soumya
