Old 26-09-2004, 10:57 AM   #1 (permalink)
AskRajesh
rajeshjsl's Avatar
Default hang after 12 to 13 seconds
i have a problem
when i run age of empire ii age of kings
after every 12 to 13 secod it hangs for 5 seconds and becomes normal
again after every 12 to 13 secod it hangs for 5 seconds and becomes normal
this repeats always
i have the latest drivers installed
i have p4 1.59 ghz 224 mb ram with 32 mb video card
rajeshjsl is offline
Old 26-09-2004, 12:57 PM   #2 (permalink)
Ethan_Hunt's Avatar
well mate u didnt give out which OS u are using anyways try reducing the tasks by removing the unwanted ones from Ctrl+Alt+Del Menu this will free up some Ram Or try rremoving the Ram Manually and cleaning it up and then inserting it firmly again.
Ethan_Hunt is offline
Old 26-09-2004, 03:59 PM   #3 (permalink)
busyanuj's Avatar
check if you have the latest DirectX 9c drivers installed.
and increase the Virtual Memory size, that should help.
also, download the Age of Empires 2 Patch
busyanuj is offline
Old 26-09-2004, 07:19 PM   #4 (permalink)
whats ur system config ??
No Mercy, No Limits.
theraven is offline
- by bhaskar
- by soumya
