Old 10-09-2005, 02:01 PM   #1 (permalink)
cybermanas
Posts: n/a
Default alcohol 120% or virtual cd
which is better alcohol 120% 1.4.5 or virtual cd 6
Old 10-09-2005, 02:18 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well Alcohol copies even the security mostly and supports MDS and other things more than VCD.
I like Alcohol, but Vcd is good enough and sometimes better if u r not a gamer.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-09-2005, 03:04 PM   #3 (permalink)
expertno.1's Avatar
virtual cd 6
Hey man
Virtual cd 7 is out !!!!
www.virtualcd-online.com
also according to your question
i prefer virtual cd coz it compresses the cd image to save space and its 200x fast
expertno.1 is offline
Old 10-09-2005, 04:59 PM   #4 (permalink)
Commander in Chief
Well even Alcohol 120% offers the same 200x speed.
Alternatively u cud use Virtual Cd and a combo of Daemon TOOLS (the best in emulation).
See this for some arguments :
http://www.msfn.org/board/lofiversio...hp/t52045.html
Harsh J
www.harshj.com
Old 10-09-2005, 06:04 PM   #5 (permalink)
Alcohol 120% and Daemons tools combined are the best... VCD is good but not as good as em..
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 10-09-2005, 06:25 PM   #6 (permalink)
vignesh's Avatar
Alcohol 120% is good mate
vignesh is offline
Old 10-09-2005, 06:58 PM   #7 (permalink)
Alcohol 120% is good one.It has fast skip error facility.so it even copy the disc faster with error.(As like source cd)were as vritual cd causes delay and some time fails.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 10-09-2005, 08:38 PM   #8 (permalink)
How about Nero's image drive????
shivaranjan.b is offline
Old 10-09-2005, 09:54 PM   #9 (permalink)
KoRn's Avatar
hey guys is alcohol 120% available on digits anniversary issue 2005? i really want it cuz i dunno where to download it from that is for free.
<<<*Liv3 F@sT Di3 FuN*>>>
<<H3@dB@nging My W@Y ThRoUGh LiF3>>
KoRn is offline
Old 10-09-2005, 10:15 PM   #10 (permalink)
Default It is a demo
It a demo version.After u install it u have to give the registration code
then only it works.It is not a free version. u have to get it. It cost
around 30$ i think.And no were u find full version.
rajas700 is offline
Old 10-09-2005, 11:06 PM   #11 (permalink)
alcohol 120% is the best!!! it bypasses most of the security, and makes iso and mds images much faster, then other programs...oh yea and free version works same way, its just that u have to wait 8 seconds more to load it...
zerohourkill is offline
Old 10-09-2005, 11:24 PM   #12 (permalink)
I prefer alcohol. It can even make copies of copy protected cd.
girish_b is offline
Old 11-09-2005, 08:06 AM   #13 (permalink)
vignesh's Avatar
It was given with august 2003 mindware.It was a trial version
vignesh is offline
Old 11-09-2005, 02:40 PM   #14 (permalink)
 Macboy
goobimama's Avatar
I think Nero's ImageDrive is the best. works like an angel on wheels....
I'm like a bird... :)
goobimama is offline
Old 11-09-2005, 03:00 PM   #15 (permalink)
Commander in Chief
Yes but nero supports only a few formats, iso, nrg etc...
it doesnt support compression like mini images and all.
Harsh J
www.harshj.com
Old 11-09-2005, 09:02 PM   #16 (permalink)
expertno.1's Avatar
why is it ur favourtie ..please post your opinion in expanded way
VCD has also fast skip error facility
and for your ifo VCD only fails when the cd is unreadable by the physical drive
well thats a simple emulator and not as much advanced as VCD and Alcohol
Both VCD and Alcohol are trial
but daemon tools are free
www.alcohol-soft.com
http://www.daemon-tools.cc/
VCD also does this and VCD 7 works best
its very basic and ite emulation is not so fast
and some features i like of VCD
In case you are already familiar with an earlier version of Virtual CD, the following list will fill you in on the new features available in version 7:
· With the Virtual CD sidebar, you can see at a glance which virtual CDs are currently in which virtual CD drives, without having to open the Windows Explorer or any other program. The VCD sidebar also gives you direct access to the main Virtual CD programs.
· The Catalog Search function has been revised and improved, and lets you access the data structure of virtual and physical CDs without inserting them.
· You can create ISO images using the Image Wizard.
· Improved data-reading capabilities make it even easier to make CDs with special formats.
· Revised analysis functions for optimized automatic creation of virtual CDs in Easy Copy Mode.
· Optimized data readout processes: with many types of CD drive, the process for creating virtual CDs is much faster than before.
· Complete support for all types of ISO-compatible images, for trouble-free exchange and use of images from any source (e.g., from the Internet).
· Define and save "Views" in CD Management to sort virtual CDs in the display according to your criteria.
· The new Virtual CD "Burner" program makes it faster and easier than ever to create exact, 1:1 copies of virtual and physical CDs. In combination Smart Virtual CD, you can now back up data that is stored on almost any medium.
· The Eraser Wizard makes it possible to delete all data, or just the table of contents, from re-writable (RW) media before you write new data on it.
· The CD Search program has been expanded so you can use it in direct combination with the main VCD functions (Copy, Create script, Burn, etc.) without having to add the images to CD Management beforehand.
· Customizable labels and icons for virtual CD drives.
· Added controls for customizing the integration of Virtual CD commands into your Windows Explorer.
· Quick Copy Editor for viewing and modifying the data stored in Quick Copy files, for even more efficient use of the Quick Copy features.
· Image Converter for converting ISO images into virtual CDs – and vice versa!
· Cataloging functions for audio CD.
· The labels and functions of Smart Virtual CDs can now be defined in the Smart Virtual CD Burner program.
Copyright© 2000-2005 by H+H Software GmbH
and the most thing i like is that it compresses the cd image to save disk space
Phew..very long post
Old 16-09-2005, 10:24 PM   #17 (permalink)
Dipen01's Avatar
My fav is Virtual CD. its the best though i have used Alcohol but i like Virtual CD . (Never tried Daemon Tools)
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 17-09-2005, 06:21 AM   #18 (permalink)
expertno.1's Avatar
Daemon tools is only emulation software
it cannot create images
it can only emulate the images of the disk
so if we have virtual cd which does both (creation adn emulation of images) then why to go for daemon tools?
thanks
regards..
Expertno.1
Old 17-09-2005, 07:02 PM   #19 (permalink)
i think alcohol 120 is better ive tried VCD with a few scratched cds of mine and it didnt work but alcohol worked
ishaan is offline
Old 17-09-2005, 07:16 PM   #20 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Trust Alcohol 1.9.5.3105 to be the best... PERIOD
koolbluez is offline
Old 18-09-2005, 12:15 PM   #21 (permalink)
Dipen01's Avatar
Well i dont understand one thing... before a year or what i was using Virtual CD 4.3 ..
at that time i just got a Video DVD from my friend . Then i didnt know how to rip it so i just made its image thru Virtual CD and for complete DVD it barely took 3 - 4 min.. and normally for a CD it takes 5-6 min.
I didnt understood how come it imaged DVD faster than CD.. and yea when i tried this with later versions of Virtual CD. it takes long time to image DVD.. Didnt get this...
Is it that some settings are to be changed or adjusted...?? or its anything different
Dipen01 is offline
Old 18-09-2005, 03:42 PM   #22 (permalink)
expertno.1's Avatar
Hi Dipen ,
It is because the DVD which u had imaged was not full i.e it might be half or less containing only 2 gb or less data
thats why it had ripped it faster
But today when u do this with the dvd (probably which is full)
it takes time
so in my sense it is normal and u dont need to worry about
second thing is also that it migth be possible that your dvd reader had become old now and as it becomes old its reading speed declines
thats why you are getting the changes
BTW u can get virtual cd 7.1 which is the latest from here
Thanks
Regards..
Expertno.1
- by bhaskar
- by soumya
