Old 10-09-2005, 08:44 AM   #1 (permalink)
vasulic's Avatar
Default S-VIDEO OUT?
Iam planning to buy a Intel P4 630 3.0 GHz Processor with Intel 915 GAVL MOB based computer . What should I have to ADD, to have a S-Video Out in my computer?
vasulic is offline
Old 10-09-2005, 10:40 AM   #2 (permalink)
It depends. You motherboard might come with an S-video out already. Else, you need a graphics card which has an S-Video out.
Nemesis is offline
Old 10-09-2005, 12:22 PM   #3 (permalink)
im not sure a 915 mobo has svideo out
the newer series does
anyways if ur going in for a new pc why u gettin the 915 ? they'll be phasing that out soon enough too
anyways your choice
get a nice gpu with svideo out afaik
No Mercy, No Limits.
theraven is offline
Old 10-09-2005, 02:22 PM   #4 (permalink)
Hi talking abt s-video i have a query 2.
My Toshiba laptop has a S-vidoe out but my Tv doesnt have it. Is there neway i can connect the 2.
I really wanna do it.
Plz try 2 suggest some simple and cheap soln(u can write if it is otherwise 2)
iammrcool is offline
Old 10-09-2005, 03:47 PM   #5 (permalink)
vasulic's Avatar
hi
iammrcool
You can buy a S-video to 3-RCA Cable. Buy a good Quality cable. Also refer
http://www.svideo.com/sv3rca.html
vasulic is offline
Old 10-09-2005, 06:14 PM   #6 (permalink)
Originally Posted by vasulic
hi
iammrcool
is it available at common electronic shops??
Old 10-09-2005, 08:56 PM   #7 (permalink)
vasulic's Avatar
Pls check in your place
vasulic is offline
Old 12-09-2005, 04:49 AM   #8 (permalink)
You can build an SVIDEO to composite cable pretty quickly since it only takes the SVIDEO and composite connectors and a capacitor to switch the signals. So it should be cheap. Do a search on here for a post I made on how to do it.
AlienTech is offline
Old 12-09-2005, 11:51 AM   #9 (permalink)
cant u just post the link here???
Old 13-09-2005, 03:08 PM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
you easily get an svideo to rca cables in electronic shops. should cost ya 50-60 bucks...however if you can build one...then the total cost should come down to rs.30 or so...
infra_red_dude is offline
- by bhaskar
- by soumya
