Old 10-09-2005, 01:56 AM   #1 (permalink)
mohanty1942's Avatar
Default IE 6 installation problem
(i) While starting installation of IE 6 in my WinXP system the following error comes. Please help for possible solution.
(ii) Also please advice how to remove the AZESEARCH toolbar [seen in above screenshot] which has set itself without prompting me.
No Terms : Just One Condition
mohanty1942 is offline
Old 10-09-2005, 06:45 AM   #2 (permalink)
expertno.1's Avatar
for your first query the problem is either with the corrupt installtion file or the winine.dll
well get a new wininet.dll from here
www.dll-files.com
for your second wuery post a hijack this log here
we wil edit it and will remove the entries corresponding to the problem
Go to "My Computer"
1)Do a Search of AZE*.*
2)Close the AZESEARCH bar
3)Delete all the files one by one.
4)Go to "Start" "Run" type regedit.
5)Go to Edit, Search, type AZE and search for all components that are related with the file and erase it (if you are note sure live it.)
6)Do another search on My computer and delete the File or files that last.
from http://www.computing.net/windowsxp/w...um/133346.html
expertno.1 is offline
Old 10-09-2005, 06:50 AM   #3 (permalink)
Download the dll file.Go to system 32 folder in windows and paste it. And then try to reinstall it.
Download at:
http://www.dll-files.com/dllindex/dl....shtml?wininet - 18k
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
- by soumya
