Old 09-09-2005, 09:22 PM   #1 (permalink)
Default Space Constraints
I have a 140 (60+80) GB HDD with 6 partitions ...
I alloted C drive of 6 GB as suggested by Digit in one of its earlier editions .. but its not enuf for me now .. in that disk only Windows is now running
I even moved the My Documents Folder and re-installed all programs on another partition instead of C:\Program Files default folder
I have only now 182 MB of free space in C drive
Does Windows occupy nearly 6 GB of Hard Disk space .. I keep deleting all of Temp folders and Temp Internet folders but still i have never had more than 300 MB of free space
I even changed the Virtual Memory to another partition
The system runs fine but I am concerned ..
Is thr a way to make this partition a bit bigger by reallocating space from another drive .. Please Help
Experts Say, Something Went Wrong With the Jet Crash ;)
D1G1TiZed is offline
Old 09-09-2005, 09:25 PM   #2 (permalink)
Check how much space you allocated to system restore function..........
shivaranjan.b is offline
Old 09-09-2005, 09:42 PM   #3 (permalink)
q3_abhi's Avatar
It do happens with me that even though the space is 4 Gb, it shows only me 1.5 GB. I donno why this happens. Is ur hardisk in good condition???
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 09-09-2005, 11:29 PM   #4 (permalink)
godsownman's Avatar
You can try with a tool Partition Magic. I think it does it . I have never tried it though.
Let someone else confirm what I said
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 10-09-2005, 12:44 AM   #5 (permalink)
no way .. win xp does not occupy 6gb of space.. probably while u were movin/deleting large files,they got fragmented.do a thorough check for disk errors ..that usually fixes such problems with wrong free space reporting.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 10-09-2005, 09:34 AM   #6 (permalink)
System Restore was earlier occuping arnd 600 MB .. now i reduced it to 200 MB .. now my C drive has arnd 400 MB free space but still isnt it too much for WinXp to occupy nearly 5.xx GB .
I think its reporting the size wrong because every now and then it shows that your system might become unstable because of low space but even with 80 MB free space and all in C drive the system was stable ...
And for defragmenting dont you need some necessary space (arnd 10% r something) .. so i dont think i can defrag without space
and i'll run thorough disk check also .. thanks neways ..
and my hard disk is .. well arnd 2 years old .. no problems till now
Old 11-09-2005, 01:07 AM   #7 (permalink)
aadipa's Avatar
Use SequoiaView to find which files are taking up space on your hard disk.
With SequoiaView u should get diagram like this tell what files u taking how much space. Each rectangle is a file on disk. Just hover ur mouse over rectangle to see the filename in tooltip. Other info about file is displayed at status bar.
make sure to select Show hidden and system files in options to view all files.
Here is what u should get
Get it from http://www.win.tue.nl/sequoiaview/
Larger the rectangle, larger the file.
Thanks to ImageShack for Free Image Hosting
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
- by soumya
