Old 09-09-2005, 06:46 PM   #1 (permalink)
Default Re:VoIP
I would like to use Internet telephony. I have a BSNL Broadband connetion. Would appreciate your comments and experiences on this issue. Which software to use etc etc. I have Windows98 and I believe Skype can only be used with Windows XP or 2000. So which will be a good solution ??
Thanks
harmads is offline
Old 09-09-2005, 08:43 PM   #2 (permalink)
Just Do It
Charley's Avatar
Who told u SPYPE doesnt work on Win98. I've been using it for many years now. It is a reliable software for VOIP. With any connection be it dial up or broadband it will work.
chck these links also
http://www.thinkdigit.com/forum/viewtopic.php?t=24476
http://www.thinkdigit.com/forum/viewtopic.php?t=25721
http://www.thinkdigit.com/forum/viewtopic.php?t=15145
Charley is offline
Old 10-09-2005, 06:50 PM   #3 (permalink)
Thanks for your reply..
On the Skype website, when you click on Windows Download, it tells you the system requirement as XP or 2000 !!
I would appreciate if you could tell me a solution for PC to Phone, because that is what I want to use...
Thanks
harmads is offline
- by soumya
