Old 09-09-2005, 10:48 AM   #1 (permalink)
Default Disabled Wallpaper Select in Display properties Desktop Tab
Hello everybody...
I use Windows XP SP2 operating system...
the wallpaper selection window in the Desktop tab of Display Properties window got disabled somehow....
how can i get it back??
thanks in advance.
vijay_v is offline
Old 09-09-2005, 02:34 PM   #2 (permalink)
goto start menu
run
type gpedit.msc and press enter
under local computer policy > user configuration > administrative templates > control panel
and click on display
double click on "prevent changing wallpaper"
set it to "not configured" or "disabled"
u may need to restart ur comp !
lemme know if it works or we'll have to find a registry key for it
No Mercy, No Limits.
theraven is offline
Old 09-09-2005, 03:26 PM   #3 (permalink)
thanks for the reply...
i did disable the "Prevent changing wallpaper" option in the comp where my wallpaper chaning was disabled... but it didnt work...
but when i do the same thing on some other computer.. this option works fine...
my problem isnt solved yet......
i have tried to find the registry key which will enable the chaning of wallpaper.. but didnt find any......
vijay_v is offline
Old 09-09-2005, 03:54 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
A registry is found at http://www.kellys-korner-xp.com/regs...aperenable.reg
dont apply it directly !
1st read it in notepad and see what is wrong then apply.
Also w8 for raven's comment on ur problem plz.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 09-09-2005, 04:00 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
open regedit and nevigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\ActiveDesktop
and look if there following two keys exist:
NoChangingWallPaper
NoHTMLWallPaper
If both or one of them exist, then change their value to 0
Now nevigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
And check if
NoActiveDesktop
NoActiveDesktopChanges
exist, if YES then change their values to 0
It should solve ur problem...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-09-2005, 08:11 PM   #6 (permalink)
@Vishal Gupta
i have checked the first option... there is no "ActiveDesktop" in the Policies key......
and about the Explorer key...
it doesnt have NoActiveDesktop or NoActiveDesktop changes strings.....
vijay_v is offline
Old 09-09-2005, 08:16 PM   #7 (permalink)
Microsoft MVP
Did u check all the keys in HKEY_USERS too?
Pls check there too...
- by soumya
