Old 08-09-2005, 12:02 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Partition Magic sideffects ! ! !
have read somewhere on net ...
using these softwares (Pmagic or others) 4 merging & resizing ur partitions R HARMFUL 2 ur system ??? u should use those only old windows techniques ...
plz can anybody shade light on this ... me confused ...
ax3 is offline
Old 08-09-2005, 04:45 PM   #2 (permalink)
expertno.1's Avatar
No Dude Merging or REsizing partitons is not harmful to your hard disk
but it is harmful to your files coz in the process any small mistake can make ur partiton unsuable and you will get lost all of your files
expertno.1 is offline
Old 09-09-2005, 11:45 AM   #3 (permalink)
ax3
ax3's Avatar
thanx 4 ur advise ...
coz me wanna merge my 2 partitions ...
... W H O T ...
ax3 is offline
- by soumya
