How to lock a Floppy disk so that no body can get access to it using any computer?
My colleague has done it. He gave me a floppy and asked me to see what is inside. As I put it into my computer and clicked on the FDD icon, it asked me for password. I tried to open it in DOS and found the same message.
I asked a lot to him for the trick, but he did not reveal. So stubborn! Help me please.
Naikosen
Try using "Bad Copy Pro". It is used to recover the data from unusable Floppy disks. Use it so that u can easily get the data inside te floppy as it isnt damaged.
Fragging is the key to Success!!!!!
He is saying that when we click 3 1/2 Floppy (A in my computer it does not display the contents instead it asks for a password and verifies if the password matches with what was keyed in first.
If it matches then it proceeds to show u the content.
Please correct me if I am wrong
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Yeah! you're absolutely right. Thank you very much for making my problem apparent to all.
It may password protected file.some can be bypassed in dos mode.that only he done.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
