Old 08-09-2005, 03:16 AM   #1 (permalink)
Default To know about SDRAM
Hey everyone
Can anyone tell me which companys 168 pin 256 MB SDRAM is the best ,if possible also give me the prize.U can send me email.
Waiting for someone who will write to me.Till then
Goodbye
kaushal_kedia is offline
Old 08-09-2005, 06:11 AM   #2 (permalink)
You can go for Zion........
shivaranjan.b is offline
Old 08-09-2005, 09:09 AM   #3 (permalink)
MVP in VC++
Kingston is good and costs approx 2600/- and next best is Hynix and costs approx 1900/-
cvvikram is offline
Old 08-09-2005, 05:04 PM   #4 (permalink)
expertno.1's Avatar
I recomemnd you to go for Hynix ..really good in SDRAM
u will get around rs. 1750
but i tell u dude that sdram is outdated ..and costly also
u shoudl update your mobo for getting a ddr sdram..the cheap and more reliable and faster than sdram
expertno.1 is offline
Old 08-09-2005, 07:24 PM   #5 (permalink)
u can get a 256 Mb ram for Rs 1300
cyrux is offline
Old 08-09-2005, 07:46 PM   #6 (permalink)
The Incredible's Avatar
from which company and how can i get it?
The Incredible is offline
Old 08-09-2005, 09:34 PM   #7 (permalink)
expertno.1's Avatar
which ram are u tlaking abt
i think thats sdram..coz the coslty thing
Old 08-09-2005, 11:28 PM   #8 (permalink)
please don't go to bye any SD RAMs cos they are costly and are also out dated as expertno.1 says.
if any time you want to upgrade your PC then your SD RAM will be useless.
if at all you want to bye it only go for Kingston RAM.
but the latest are the DDR2 RAM(too good i must say).
sam\'s
samleo109 is offline
Old 09-09-2005, 09:05 AM   #9 (permalink)
are DDR and DDR2 interchangeable or should we opt for motherboards with DDR2 compatibility
Experts Say, Something Went Wrong With the Jet Crash ;)
D1G1TiZed is offline
Old 09-09-2005, 04:10 PM   #10 (permalink)
Do any 1 know abt moboswith DDR2 compatibility?
@D1T1TiZed
what did u mnt by interchangeable?
Old 11-09-2005, 02:47 PM   #11 (permalink)
Thanks for replying
I will go for HYNIX 256 MB SDRAM and as it said in the replyies that it will not cost me anymore than RS 1750..I cant change my processor as it is working fine fine now.
thanks
Old 16-09-2005, 12:10 AM   #12 (permalink)
BOL kaushal.
BTW
ppl
plz let me know wat's interchangeable mentioned above stands for?
Anindya
Old 16-09-2005, 05:16 AM   #13 (permalink)
I think By interchangability he is meaning the backward compatability with DDR....
Old 16-09-2005, 05:49 PM   #14 (permalink)
u mnt that i can also insert sdram in ddr ram's slot?
Old 16-09-2005, 05:54 PM   #15 (permalink)
Old 16-09-2005, 10:35 PM   #16 (permalink)
Default RAM
No u cant plug DDR RAM in SDRAM socket because PC100 has got 168 pin and the DIMM Socket supports only 168 Pin RAM.So because of it i have to stick to SDRAM(PC100) as this is only option i am having right now.Can u please tell me the Price at which i can get HYNIX-256 MB SDRAM(PC100-168 PIN).Thank you
Old 17-09-2005, 01:55 PM   #17 (permalink)
Default Re: RAM
I asked that whether i can plug sdram in ddr ram's slot!
visit www.zionram.com
there u'll found an e-mail id. just mail them. its gud for u if u mail them urself. i think u'll get experienced.
they'll surely tell u da price.
also u can ask if there is any seller in ur city. n i hop they can answer it also ot they'll send u ram via courier .
just visit da site mail them n u'll solve ur problem.
Anindya
Old 17-09-2005, 07:07 PM   #18 (permalink)
i think kingston rams r da most reliable and r btr dan all the other ones...followed by hynix
ishaan is offline
Old 18-09-2005, 12:56 AM   #19 (permalink)
i don't thinks so.
even digit don't thinks so
- by soumya
