Old 06-09-2005, 01:37 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default total ram 256 availble ram 14.5?????????????????????????????
my system information is as follows:-
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name KL-TAR4KNBNUNTA
System Manufacturer MICRO-STAR INTERNATIONAL CO., LTD
System Model MS-7142
System Type X86-based PC
Processor x86 Family 15 Model 12 Stepping 0 AuthenticAMD ~1999 Mhz
BIOS Version/Date Phoenix Technologies, LTD 6.00 PG, 6/1/2005
SMBIOS Version 2.3
Windows Directory C:\WINNT
System Directory C:\WINNT\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
User Name KL-TAR4KNBNUNTA\gaurish
Time Zone India Standard Time
Total Physical Memory 256.00 MB
Available Physical Memory 14.50 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 465.19 MB
Page File C:\pagefile.sys
how 2 increase phy ram
i have a ddr 400mhz single chip
gary4gar is offline
Old 06-09-2005, 04:02 PM   #2 (permalink)
You can only increase physical RAM by adding more RAM to your PC. 256 MB is too less.
drvarunmehta is offline
Old 06-09-2005, 04:33 PM   #3 (permalink)
expertno.1's Avatar
how could that be ?
btw @gary4gar
can u tell me from where you got this info ?
well if this s true then the thing is that after runnign computer for a long time the ram gets filled and u need to recover its memory agin by using ram optimizers like
memzilla , sys mechanic ram defragmenter , etc
you will also need to add more ram coz 256 is less dude
expertno.1 is offline
Old 06-09-2005, 09:57 PM   #4 (permalink)
mario_pant's Avatar
just check in the task manager what app is using what...... just end mega resource hungry apps and try not to open more that 3 to 4 apps at a time....
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 07-09-2005, 04:52 AM   #5 (permalink)
Fresh Stock Since 2005
Use Memory Optimizer from Systweak.com ...........
And what is so much of a problem in having only 14 Mb memory free?? hehe..........
To view info on RAM, ou can also download _khAttAm_'s Kefile me V3 from http://crackmes.de/users/khattam/kha...me_v3/download
This will need a valid keyfile to work properly, but you can either crack it or wait till it is cracked if you'd like to use it................ hehe
Alternately, you may also use _khAttAm_'s unUPX me, from http://crackmes.de/users/khattam/khattam_s_unupx_me_v1/
http://www.khattam.info
khattam_ is offline
Old 08-09-2005, 12:18 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
i got this information from
start>all programms>accessories>system tools>system information
i closed all the applications and even nortain auto protect,webshots,outlook express etc.
still does not go over 83.5
pls help!!!!!!
i am also confused and my system hangs often when i play games like gta III just for 20 min
when i reboot a msg displays ur system has recoverd frm a serious error.some time get a blue screen of death.after reboot it saysur display device
via\sg3 unicrome igp pro is the cause for instabilty
pls NOTE TEMP DOES NOT RISE ABOVE 50 C
ANYTIME
HELP!!!!!!!!!!!!!!1
gary4gar is offline
- by soumya
