Old 06-09-2005, 12:32 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Spybot 1.4 problem during updating.
uninstalled Spybot 1.4 last evening and reinstalled it back and when updating takes a lot of time to do so. Even after 1 hr it doesnt update.
Is there a Zip file or anyother where I can update Spybot rather than downloading thru the software itself?
Charley is offline
Old 06-09-2005, 01:52 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
When the updates are listed in Spybot. Just don't press download and hover your mouse over each of the updates and you will find the full path of respective update listed. Just copy it as it is on your D/L Manager's Copy Url Window and download manually. Each update will be in a zip file. Just extract the contents into their respective folders in C:\program files\spybot - search & destroy.
navjotjsingh is offline
Old 06-09-2005, 07:27 PM   #3 (permalink)
Just Do It
Charley's Avatar
it worked i.e. I changed the server to d/l from Australia to Europe, it worked well
Tks
<< Cheers >>
Charley is offline
Old 06-09-2005, 09:30 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
man, njs is the best ! a lot to learn from him ! tusi great ho !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 06-09-2005, 11:40 PM   #5 (permalink)
I am Optimus Prime
Thanks anandk for the compliment. Tusi is naachiz to ani izzat bakshi. Shukriya.
- by soumya
