Old 05-09-2005, 11:27 PM   #1 (permalink)
Default few little queries about console options!
hi all,
can U plzz tell me how to check the disk space of each drive individually through console i mean at command.exe ....
& one more ....
when we run any batch file .. there is a console window which gets displayed .. can we hide that window from being displayed while the batch file is RUN! .
plzz these queries are important! .. thanks! in advance!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 05-09-2005, 11:31 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can hide the console windows by Right-clicking on it and select Run as Minimized, then it'll run as minimized and will not be visible...
And for check the disk space u can run fdisk /status command ( but its available only in Win 98 ).
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-09-2005, 12:22 PM   #3 (permalink)
THanks! Vishal ... but abt the disk space i need it for XP .... newayzz thanks! for ur solutions ..
Old 10-09-2005, 05:35 PM   #4 (permalink)
plzz somebody respond! its urgent!
Old 10-09-2005, 07:16 PM   #5 (permalink)
swatkat's Avatar
Hmm...In 2000/XP, you can use the command chkdsk X: where X: is the Drive Letter of your choice, though this command does lot more than checking Disk Space.
But, there's a Resource Tool Kit is available for Windows 2000, which has a command called freedisk to show Free Disk space. You have to extract this file related to this command either from CD or from a website. This MAY work in XP too!
You can download Freedisk.exe here.
http://swatrant.blogspot.com/
swatkat is offline
- by soumya
