Old 05-09-2005, 10:29 PM   #1 (permalink)
Default DO U KNOW??
BSNL Dailup user can use one ID AND PASSWORD and TWO can login at a
TIME and Browse.For example:If 'x' logins at 6.00 p.m using HIS ID AND
PASSWORD.And made logout at 8.00 p.m.During these time'y' can also
login with 'x' ID AND PASSWORD and he made logout at 7.45 p.m means
only 2 hours get reduced in 'x'account.And these is a benefit for 'y' .
Likewise friends can exchage there ID AND PASSWORD If they wish .
And avail a benefit if both surf's at a time and save money.
rajas700 is offline
Old 05-09-2005, 10:33 PM   #2 (permalink)
godsownman's Avatar
Hi,
Keep that as a secret or else if BSNL comes to know about the Flaw in their product they shall stop it and everybody will suffer.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 05-09-2005, 10:44 PM   #3 (permalink)
good one...
raasm287 is offline
Old 05-09-2005, 10:58 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
I just fail to realize why dont all those who use BSNL as an ISP use VSNL. Get a second line from BSNL (499/399 Rs monthly) and instead of using BSNL as the ISP which charges on the time duration, use the VSNL 30 days unlimited package for 331 Rs. So within 800 Rs. you have a 24 hrs online connection in case you dont have narrowband providers in your area.
Even if you dont have the second line, paying 8rs or so per hour is way too much in the end if you use more than 1-2 hours per day as you can buy that unlimited package from VSNL.
I guess many people have a doubt about a VSNL dialup account working on BSNL line. Its just a difference of 4 numbers 172226 instead of 172233.
Sourabh is offline
Old 05-09-2005, 11:18 PM   #5 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
hey wont the hours used by both of them be cut...ie. if x logs on at 6 and y does the same then logs out at 7 and y does the same... hence wont 2 hrs be cut? for 2 friends?
Moreover.... the hrs are free from 11 pm to 8 am... and free on holidays and on sundays... 8)
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 05-09-2005, 11:34 PM   #6 (permalink)
Hello in BSNL second line from BSNL (499/399 Rs monthly)will work only
172233 and not 172226.ok.And i have confirmed with the BSNL authorites
IS IT WORK FOR U?AND HOW AND WERE TO CONFIRM AGAIN CAN U
GIVE CONTACT NUMBER?BECAUSE I USE SECOND LINE ONLY( 399 Rs)
AND NOT WORK'S FOR ME.SO GIVE THE CONTACT BY MESSANGIG
PRIVATELY IT WILL BE HELP FULL FOR ME.
rajas700 is offline
Old 05-09-2005, 11:40 PM   #7 (permalink)
SIMPLY NO.ONLY 1 HOUR GET REDUCED.TO SATISFY U VERIFY URSELF
AND UR FRIEND.
rajas700 is offline
Old 06-09-2005, 12:01 AM   #8 (permalink)
Laptoping
Sourabh's Avatar
@rajas700: Caps Off Please. Yes it very well works and u can dial any ISP with 172xxx numbers from the BSNL second line. Buy a package if you are so willing to try, it works for sure. or try getting hold of any person who has an VSNL account and try to connect with that. IF it works go ahead and buy the 1 month unlimited package
Sourabh is offline
Old 06-09-2005, 12:19 AM   #9 (permalink)
I have tried to dail in BSNL second line with 172226
it says that dailcode dose'nt exist.so only i want the
BSNL authorites contact number it will be help full
for me.so give it.so i can contact them and get it
for me.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 06-09-2005, 12:22 AM   #10 (permalink)
Laptoping
Sourabh's Avatar
Check their website or call the telephone exchange and enquire. It wont be difficult to find.
Sourabh is offline
Old 06-09-2005, 06:14 AM   #11 (permalink)
It works only in some area.
rajas700 is offline
- by soumya
