Old 05-09-2005, 07:41 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Scheduling time to start and end process.
Is there a way to set a start and end time for a schedule. I require it for using it during the DATAONE, free hours [ 2:05AM - 7:55AM ].
I can leave the comp on but it should start and end at the above mentioned time, is it possible? If yes, how do I proceed?
Also, is there an option in Win98 SE where the comp switches off automatically instead of manually pressing the button to save power after the schedule is complete.
Charley is offline
Old 05-09-2005, 07:53 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Some download managers like ... well, flashget, or getright (dunno bout DAP) ..support schedule connect and dissconect and shutdown after complete features...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-09-2005, 08:06 PM   #3 (permalink)
Just Do It
Charley's Avatar
Rflol, this is for P2P d/l and u/l not what u think.
Pls somebdy gimme a advice.....
Charley is offline
Old 05-09-2005, 08:27 PM   #4 (permalink)
Commander in Chief
Oh yeah ?
Then u shud ave mentioned it earlier m8, lolz u didnt !
U dont give info and lolz on others ?
Harsh J
www.harshj.com
Old 05-09-2005, 09:03 PM   #5 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Use a scheduler like Aye Shutdown it can end any task or program and shut internet or power off pc at any given time. it is shareware.
navjotjsingh is offline
Old 05-09-2005, 09:12 PM   #6 (permalink)
Hey man use IDM.. internetdownloadmanager.com. It allows to set time to start download and time t o stop download... I use that..
It also has the option to shutdown the comp after all downloads in the scheduler are completed
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 05-09-2005, 10:06 PM   #7 (permalink)
Just Do It
Charley's Avatar
Charley is offline
Old 06-09-2005, 08:59 AM   #8 (permalink)
instead of using a software, u can do this:
Open Notepad--> type this: shutdown -r t 00 --> and save it as restart.bat --> Now open scheduler and give the path to this file and set the time wenever u want to start this operation.
Well the thing is u will have to keep ur computer switched on for this to happen.
You can give any name to the file and 00 is the time u want yo show warning for that the computer is shutting down. Then with a time gap of say 5 minutes, start the download managers/bit-torrent clients that u download with and u r done.
If u have 2 or more user accounts, u can use MS tweakUI to force a particular user to log on. The u can disable the automatic user log on again in the morning. Hope this helps you.
Shwetanshu Srivastava
shwetanshu is offline
Old 06-09-2005, 12:25 PM   #9 (permalink)
Just Do It
Charley's Avatar
Sorry, I couldnt follow u. I want to set the time for 2:10 am[start] and 7:50 am[stop]. It should shut down precisely at 7:50am as that completes the free usage for each day. What should I do?
Also comp has to shut down automatically at 7:50 am.
used for Kazaa d/l's and u/l's.
OR
Can u set a file and send me so I can add it here?
Charley is offline
Old 06-09-2005, 12:27 PM   #10 (permalink)
Just Do It
Charley's Avatar
There r 3 softies in ur link, which 1 is it?
Charley is offline
Old 06-09-2005, 12:56 PM   #11 (permalink)
selva1966's Avatar
I am using flashget 1.71. I have tried scheduling. But did't work. No details available in their werbsite. I tried google also but did't find any link.
I did not require shutdown, I will be awake by then
Can anybody help me.
WHEN THERE IS LIFE, THERE IS HOPE...
TILL THERE IS BREATH, THERE IS HOPE
Give free food with one click to a poor Indian.
http://www.bhookh.com/
selva1966 is offline
Old 06-09-2005, 01:08 PM   #12 (permalink)
I am Optimus Prime
Aye Parental Control and Aye Shutdown both can do your job. You can chhose anyone of them acc. to your needs.
Old 06-09-2005, 07:29 PM   #13 (permalink)
Just Do It
Charley's Avatar
Gee,Ok, I'll try that . But the software is a Trial ware, any freewares to source it from?
But I require some more advice on it.
Someone else pls throw some light on it.
Charley is offline
Old 07-09-2005, 06:53 PM   #14 (permalink)
aadipa's Avatar
SwitchOff is stutting down my PC for ages.
Try it...
http://yasoft.km.ru/eng/switchoff/
Overview
Switch Off is a tiny easy-to-use tray-based system utility that can automatically perform various frequently used operations like shutdown or restart your computer, disconnect your current dialup connection, lock workstation, etc. It also provides fast access to this operations through system tray icon. Utility has fully customizeable Web interface, that allows you to initiate operations mentioned above remotely from any computer with web browser installed. Web interface includes WAP support, so you can control your computer from mobile phone. This utility is intended to be used by either novice or professional user, because of its intuitive interface and professional features.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 07-09-2005, 08:46 PM   #15 (permalink)
Just Do It
Charley's Avatar
Aadipa, this is nice. Its a freeware and also small in size. I was looking for softwares as these.
<< Cheers >>
Charley is offline
Old 07-09-2005, 09:52 PM   #16 (permalink)
You can use nncron to connect to the internet shedule you r downloads disconnect from the internet and then shut down ur pc . ALl in one.
cyrux is offline
Old 13-09-2005, 03:45 PM   #17 (permalink)
I am Optimus Prime
You can use tips from this page: http://hacks.oreilly.com/pub/h/2879
or use Shutdown Monster (Freeware) from http://www.softpedia.com/get/System/...-Monster.shtml
Also more freeware softwares like these at
http://www.softpedia.com/catList/117,1,1,1.html
http://www.softpedia.com/progSearch/Shutdown%20Monster
- by soumya
