05-09-2005, 07:32 PM
Care 4 UPS
I got an APC 500W UPS.....I wont be using my comp for about 2 months...Wat care shud I do to take care of my UPS battery???
Bitten by the open-source bug...
05-09-2005, 08:38 PM
Just ru your PC or any electronic gadget on the UPS till the battery is totally exhausted. And also rmember to pull out the mail plug.
07-09-2005, 10:52 PM
you can also just leave it on...switch off the plug on the UPS but keep the power supply on
08-09-2005, 01:45 AM
You can also just leave it on...switch off the plug on the UPS but keep the power supply on
I totally agree. Its cos it keeps charging itself. And when it reaches a max it jus' stops charging more. And generally there is no such problem when left like this as its a very common incident for students going back to their places in holidays.
08-09-2005, 09:17 AM
MVP in VC++
Yup even i just left it for charging when i went to long trip....i faced no problem in my ups.
08-09-2005, 04:58 PM
since you will be not using the ups for two months
the best would be to keep the switch of your UPS off
but keep the switch off the mains to ON
this will make an automatic harging mode
when ur battery is getting exhausted (due to time) it will be automatically charged
or u may use the ups for other purposes also
hey i use my ups even to watch TV....will it harm my ups or my tv ?
08-09-2005, 06:13 PM
Senior Member
do not leave it for charging for long hours....overcharging is not good for your UPS. the battery life decreases due to overcharging. i used to do the same...then my UPS got spoilt and now i switch off the UPS when not in use.
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
08-09-2005, 08:22 PM
Never leave a ups battery or for that matter any lead acid battery fully discharged. It will be "dead" in a few days, this is due to a process called sulphation where the lead converts to lead sulphate and this is an irreversable process. Alwase charge the battery and then store it in a cool dry place.
**** happens
08-09-2005, 08:44 PM
So many contradictory suggestions...I m totally confused....Wat to do???
08-09-2005, 09:17 PM
@bizzare try what
ishaan,crashuniverse,expertno.1,pradeep_chauhan
said they all are in one point to regular charge the ups
anyone plz answer this
30-03-2006, 09:45 PM
I recently kept my UPS just next to my monitor and the monitor has started flickering...Will this cause any harm to the monitor?
30-03-2006, 11:00 PM
Never keep any device which causes magnetic field near a CRT displat it will affect it badly
30-03-2006, 11:18 PM
@expertno1
It depends on your tv's wattage. If your tv has more wattage than your ups can handle, then its definetly bad for your ups.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
30-03-2006, 11:21 PM
No problem in using tv it will not damage either the UPS or the TV
31-03-2006, 12:22 AM
Very correct and to be followed by all.
V.Prem Kumar
V.Prem Kumar
31-03-2006, 12:25 AM
Not exactly. Depends on capacity of UPS and consumption/size of the TV. Also take into consideration, the heavy surge current taken by the TV when starting.
V.Prem Kumar
V.Prem Kumar
31-03-2006, 06:40 AM
V.Prem Kumar
No TV is going to use that much power(500VA) and what do u think ur monitor doesn't take the heavy surge current on starting.
31-03-2006, 08:22 AM
V.Prem Kumar
Please try connecting a 21 inch Sony TV to your 500 VA UPS and if it works, I will agree with you.
V.Prem Kumar
V.Prem Kumar
31-03-2006, 10:13 AM
#19 (permalink)
@janitha my 29 inch one works
Search this Thread |
