Old 05-09-2005, 06:40 PM   #1 (permalink)
Default Monitor power settings not workin' properly
Hi all,
this problem is absolutely silly to ask here. but i have no clue what the problem is.
my screensaver is set to 1 min and turn off monitor at 2 mins. now i m pretty sure i have this only profile activated, the settings as i said but what happens dat it doesnt always behave the same.
screensaver works fine at 1 min bu at 2 min monitor doesnt switch off itself all the time. i mean it switches off only 25% times and i could not observer any sequence, its bsolutely random. may happen, manot.
Rescue me.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 06-09-2005, 02:05 PM   #2 (permalink)
hi all,
isnt' there anybody who can try fixin' it
at least jus' a try.
PriyaRanjan Singh
Old 06-09-2005, 03:41 PM   #3 (permalink)
expertno.1's Avatar
dude
if you have to leave your computer fulllly idle for 2 minutes then only your monitor will off
and abt 25% times this happens that you leave your computer fuly idle for 2 minutes so the monitor goes off
but 75% times you do some movements either on mosue or on keyboard thats why it doesnt goes power off
well if this is not the problem then the problem is with your monitor..go check it with the technician
expertno.1 is offline
Old 07-09-2005, 07:20 AM   #4 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
expertno.1 wrote : dude
Then how will the screensaver will be active?
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 08-09-2005, 01:38 AM   #5 (permalink)
yes, i am sure that i leave the systems idle. i ma not that careless u see.
I really wont do that. I want more help. Anybody else.
PriyaRanjan Singh
Old 08-09-2005, 05:15 PM   #6 (permalink)
expertno.1's Avatar
the screensave will be active after 1 minute only when u have marked this screen save "wait" 1 minute
Old 11-09-2005, 10:00 AM   #7 (permalink)
vandit's Avatar
I mean that if the monitor doesn't go off after 2 min.. and the screen saver is still running that means that no movement of mouse and keyboard has been made in that case the monitor should switch off 100% times.... exp.no1...
vandit is offline
Old 11-09-2005, 10:03 AM   #8 (permalink)
vandit's Avatar
in case u are using linux ( I faced this in suse) the power management services should be available to the account u are loggin. in.... try turning it on from the yast...
vandit is offline
Old 11-09-2005, 02:16 PM   #9 (permalink)
Gracias Senor
dreams's Avatar
try 2 disable the screen saver and then check whethr the monitor turns off..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
- by soumya
