Old 05-09-2005, 05:20 PM   #1 (permalink)
Default Newer Semprons are really 64bit or ?
Are newer Sempron 2500+, 2600+ really 64 bit processors,
I Recently Buyied 2500+ for Rs 2400, I checked on various Sites they say that it is 64 bit.....
But AMD is not advertising it as a 64 bit processor,
Why is this....
Anurag
dabster is offline
Old 05-09-2005, 07:28 PM   #2 (permalink)
Aniruddh's Avatar
yeah dey r 64bit.dabster i wanted 2 kno wats ur config i mean mobo and all and it has been how long since u r using dis rig?how much did it cost u?
Aniruddh is offline
Old 10-09-2005, 06:30 PM   #3 (permalink)
i dont think so.
I bought a sempron 2800+ abt 2 months back and nowhere is it mentioned that it is a 64 bit processor.
btw think 4 urself can u get a 64 bit processor for so low as 2400??
iammrcool is offline
Old 11-09-2005, 05:37 AM   #4 (permalink)
sidewinder's Avatar
Originally Posted by iammrcool
i dont think so.
Sempron 2500 64 bit is available for 2400 nd Sempron 2600 is available for Rs 2850
There r also non 64 bit versions available so watch out.Non 64 bit versions actually costa more or less the same
Bombina rocks
sidewinder is offline
Old 11-09-2005, 09:15 AM   #5 (permalink)
rachitboom2's Avatar
Yes Sempron really are avaliable in 64 bit for as low as 2400 nowerdays !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 11-09-2005, 11:28 AM   #6 (permalink)
is there neway by which i can no whether my sempron is 64 bit or not??
Old 11-09-2005, 02:14 PM   #7 (permalink)
gxsaurav
Posts: n/a
download CPU-Z or everest, it will tell U weather U have 64bit capable CPU or not
Old 11-09-2005, 04:53 PM   #8 (permalink)
Or you could check the OPN[Ordering Part Number] which can usually been seen through the box transparent window.
Check the AMD website for sempron 64-bit OPN.
www.Oobertech.net
digen is offline
Old 11-09-2005, 05:05 PM   #9 (permalink)
1. See at th My computer properties
2. Use any software like CPU-Z, Everest, etc.
3. See the box
4. See the Processor's core itself (only if you can remove the heat sink safely).
5. Like digen suggested
6. And many other ways !!!
- by soumya
