Answer's
1.Your question isnt exactly direct... The chipset is the component that basically makes up your motherboard.. Its divided into 2 main parts.. First you have your NorthBridge (controls most primary functions) and your Southbridge (the left over good'ins) Your chipset carries a very common name im sure such as Intel 815G 865G 925x 915G : AMD (no longer making chipsets) Usually with an AMD setup you will have a 3rd party chipset such as VIAK8T800 or VIA KM-266.. Among the more popular AMD compatible chipsets are by nVidia such as Nforce 2 etc... I hope this helps you further identify what a chipset actually is and to further your knowledge of computer components!!
2.915 dose not supports 98.I use 865 GBF it supports 98.
3.It’s an urban legend. From time to time you’ll see
postings claiming that Windows 98, SE, ME, NT, 2000 (take your pick)
can recognize only 64MB, 128MB, 256MB, or who-knows-how-many megabytes
of memory. In fact, all modern versions of Windows can handle 2GB of
memory; far more than most of us are likely to encounter in the
foreseeable future.
There’s one minor gotcha, though: A bug in Windows 95, 98, SE, and ME
crops up if you have more than 512MB of memory installed. The part of
Windows that moves files in and out of the main computer sets aside
enough memory so it can work with big files, and if the amount of
available memory is large, the memory chunk that’s set aside is large,
too. Unfortunately, if the amount of available memory is huge—more
than 512MB-the file—handling routines can grab so much memory that
nothing is left for more mundane functions. Paradoxically, if Windows
hits this bug, it may report the problem to you by saying “There is
not enough memory available to run this program. Quit one or more
programs, and then try again.� Or it may hang completely.
To warn Windows that you have more than 512MB of memory installed, add
the following line to the [VCache] section of your win.ini file:
MaxFileCache = 524288."
4.Refer in
www.intel.com
5.No win98 supports only FAT and FAT32 file format.
6.Refer in
www.sony.co.in.
