Old 05-09-2005, 12:41 PM   #1 (permalink)
linardni's Avatar
Default Memory card? Multimedia Card? Memory Stick?.....confused
I want to buy a 128 MB storage device for my Kodak easyshare CX 7220 digicam. What will I go for Flash Memory card? Multimedia Card? Memory Stick?.....totally confused!!! Please recommend the brand and price also.
linardni is offline
Old 05-09-2005, 01:49 PM   #2 (permalink)
chinmay's Avatar
Well, your camera only supports SD and MMC cards...
SD cards are based on the older Multi Media Card (MMC) format, but are physically slightly thicker and boast higher data transfer rates. It would cost you slightly higher than MMC and I don' think transfer speed would matter much.
MMC cards are slightly thinner and is technically older than SD and would cost you less.
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 05-09-2005, 01:56 PM   #3 (permalink)
club_pranay's Avatar
well it's always recommended to buy genuene cards like sony and panasonic etc
you can go for brands like NCP they have quite nice quality for a very low price
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 05-09-2005, 06:23 PM   #4 (permalink)
chinmay's Avatar
NCp is not cheap maan ... there are hel lot of duplicate NCPs in Delhi whcih are sold at trash price and I think you are mistaken by it. Transcend provides best VFM in case of cards as in Delhi
chinmay is offline
Old 06-09-2005, 03:55 PM   #5 (permalink)
linardni's Avatar
I have got a NCP MMC (128 MB) against Rs.1000/- but I am not sure whether the price is reasonable & whether it's original. How will i be sanguin abt its genuinity?
linardni is offline
Old 06-09-2005, 08:19 PM   #6 (permalink)
I have a sony cybershot DSC F-88 and i want to buy a memory stick for the cam in capacities over 128mb....
One of my friends said that transcend makes memory stick and it is cheap... If so is it available in chennai??
Please let me know the rates for the sony or any other brand's memory stick
Regards...
shivaranjan.b is offline
Old 06-09-2005, 08:53 PM   #7 (permalink)
Here is the avg pricing u should get for NCP cards +- Rs. 50
NCP 128 MB Dual Voltage RSMMC Rs. 1000
NCP 256 MB Dual Voltage RSMMC Rs. 1550
NCP Reduced Sized MMC 128MB - RSMMC Rs. 700
NCP Reduced Sized MMC 256 MB - RSMMC Rs. 1000
NCP Reduced Sized MMC 512 MB - RSMMC Rs. 1550
NCP Multimedia Memory Card 128 MB - MMC Rs. 700
NCP Multimedia Memory Card 256 MB - MMC Rs. 1000
NCP Multimedia Memory Card 512 MB - MMC Rs. 1500
NCP Multimedia Memory Card 1 GB - MMC Rs. 2550
NCP 512 MB Dual Voltage RSMMC Rs. 3200
I\'M BACK
khandu is offline
Old 07-09-2005, 12:00 PM   #8 (permalink)
may be you are right chinmay, but the rates offered by sony/kodak are way beyond the ones stated by khandu
i was getting a 256mb mmc (original sony from Dass Studios CP) for Rs2100
Old 07-09-2005, 12:09 PM   #9 (permalink)
linardni's Avatar
thanx for the replies from different members. i am enlightened
linardni is offline
- by soumya
